Author Subject: Gti 180 Power
smithy pug rally
Hey guys just bought a Gti 180 to put into my Gti 138 206. Just wondering how much of the loom needs changing or does some one make a converstion loom. And how much power can be made by simple mods e.g cams, remap, exhaust, fuel pump.??
Posted 11th Oct 2010 at 00:36
cwspellowe
www.306gti6.com Wink
Bye bye Sundance Kid Sad
mr swampy s16
**BAD SELLER**
plenty of 206 forums about who im sure will be able to help more!
Posted 11th Oct 2010 at 00:40
oldbrownshoe
Try Matt at Pug1off for loom conversion.
the problem is that you'll get Gti180 power plant without GTi180 rear traction,
the rear suspension is different from other 206
"The suspension system has also had a good going over, with stiffer springs at the front, and tie rods at the back to improve rear axle stability and limit lift off oversteer, which is when backing off mid-bend produces a sudden rear end slide – something for which the sharp-handling 205 GTi was legendary. "
"The second thing is that the SW drives a lot more firmly than my previous car. The rubbers of the rear suspension are not as soft as from the normal 206, where it’s done to give the car a bit of a steering rear (and making it sometimes a bit too tail happy). To loosen up the SW’s tail, Peugeot has mounted a stiffer anti-roll bar, and this solution gives the rear of the car a bigger slip angle, instead of a rear axle that steers on flexing rubbers.
As a result, this construction makes the SW (like I already said) much more stable at high (-er) speeds, and at the same time more controllable in a 4-wheel drift."
"The SW rear axle is significantly different from the normal 206: Two ties are added between the suspension arms and meet in the middle onto a cast alloy stay, wrapped around the axle body.
It comes with Ø20 mm spring bars, a 22 mm anti-roll bar and stiffer shocks.
This layout set-up was originally designed for the 306 Maxi by Peugeot Sport and is, next to the SW, now also used in the 206 RC/GTi180, which was introduced in France halfway into 2003. "
French military victories?
Did you mean French military defeats?
Posted 12th Oct 2010 at 04:25
lotek
the beam in that pic looks like it should of been on a 6 Yes
Posted 12th Oct 2010 at 14:21
SteviePut
Why? The 6 handles fine with out it plus think of the extra weightWhistle
Posted 12th Oct 2010 at 14:26
lotek
all that crossed my mind was replacing those extra rods on there with some thick f*ckers!
alot cheaper than buying 25mm torsion bars LOL
Posted 12th Oct 2010 at 14:29
