Author Subject: Power steering problem
swiftyboi006
I am getting a horrible squeaking noise wen I turn left any ideas what this could be?
Black p3 Love
Posted 10th Oct 2010 at 22:48
hismastersfinger11
a trapped rodent???
loose track rod end? elaborate on the type of squeak.
This site is my mechanical bible, Thank-you everyone!!
Posted 10th Oct 2010 at 23:56
Maybe check for pedestrians before turning?
Posted 11th Oct 2010 at 00:46
:: blade ::
strut top mounts
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 11th Oct 2010 at 04:45
daveyboyholt
Have you checked the fluid level?
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 11th Oct 2010 at 18:17
swiftyboi006
I was told it was the pas pump so i changed it toped back up with fluid and it stoped for a couple days now its back ggggrrrrrr does that mean its the belt n should i get it changed?
Black p3 Love
Posted 19th Oct 2010 at 05:38
mabgti
NV motors
its the bearing in the pump on load.. a replacement pump is neededYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 19th Oct 2010 at 21:26
swiftyboi006
But iv already changed the pump n it came back after a day or two.
Black p3 Love
Posted 24th Oct 2010 at 18:36
swiftyboi006
Bump this problem is still going. Changed the pump for a recon 1 its def not the belt because it still pesists wen sprayed with wd40. Are there any other ways or things i can do to check this?
Black p3 Love
Posted 24th Nov 2010 at 20:59
