Author Subject: S16 BE3 transmission
hdk_wg
My box are noisy during engine runing ( idle), but when i press the clutch pedal noise will gone.
wg
Posted 10th Oct 2010 at 19:31
mr swampy s16
**BAD SELLER**
Sounds like the clutch release bearing rather than the box itself
Posted 10th Oct 2010 at 19:56
JWP EFi
Turbo Legend!
if the noise is present when clutch is out then surely the release bearing won't be the problem, as a worn release bearing would be noisy when clutch is pushed in
Posted 10th Oct 2010 at 23:39
hdk_wg
Hi, 666,
What do you mean? Do i need to bring the box down and change the release bearing?
wg
Posted 11th Oct 2010 at 06:52
ablister
normally if the noise goes away when clutch is pressed, it's the gearbox as the drive is taken away from it. If the noise gets worse when clutch is pressed then it's the clutch release bearing
306 rallye, Richard Longman engine
rc10gt
Posted 12th Oct 2010 at 01:55
hdk_wg
This morning removed the oil sum notice the trustwasher whorn out.
Replace it hope this solve the problem.
wg
Posted 12th Oct 2010 at 13:39
JWP EFi
Turbo Legend!
removed the oil sump???... to replace release bearing, i must have been doing it wrong for yearsWink
No sarcasm intended
Posted 13th Oct 2010 at 00:35
hdk_wg
Replace trustwashers dosen't help, the noise still there, crog, crog during idle. Removed the transmission inspect the clutch bearing and main shaft bearing no sign of worn out. I just replace the gear oil, using elf GL4.please help?
wg
Posted 13th Oct 2010 at 05:20
ablister
i'd say it was your gearbox input shaft bearings then, not expensive to buy but gearbox needs to be stripped Sad
rc10gt
Posted 14th Oct 2010 at 03:38
hdk_wg
Thank you for the info, I thing so. Will install a
nother box. Do I need special tool to strip the box?
wg
Posted 14th Oct 2010 at 05:23
