Author Subject: Brake caliper bolt spacing
rich-6
Is anyone able to give me the bolt spacing on a GTi Caliper? Thinking of doing the Brembo conversion on my car Ninja
Been on the net the last 2 hours trying to find out as its not going on a 306 Laugh
Cool
RIP Pete Sims
Posted 10th Oct 2010 at 18:46
pugheaven
surely you will need the bolt spacing of the car you intend to put them on then?
Posted 10th Oct 2010 at 19:06
rich-6
Yup, Hopefully i'l find out what the measurements of the 306 caliper are on here, go out to my car, remove caliper, Have a measure if its the same.
Source some calipers and work out what offset and size disks i shall need, Hopefully sub £300 Brembos Smile
I'm trying to work my way round it without having to get brackets made up, I fancied the 197 Brembos but would need to get fabricating to get them to go on Sad
Cool
RIP Pete Sims
Posted 10th Oct 2010 at 19:28
rallyestyle
Im a little lost, if its not going on a 306 then why do you need to know the bolt spacings of a gti6 caliper? Unsure
Just Drive It
Posted 13th Oct 2010 at 14:53
lotek
because gti6 calipers have the same measurements as the brembos in terms of distance between centre of holes.
and he doesent have bremobs available so needs to use the measurement of gti6 , to gauge possibility of brembos fitting his car Wink
Posted 13th Oct 2010 at 15:04
rallyestyle
Ah right that makes a bit more sense Yes
The distance you need is 82mm Rich (centre to centre) Thumbs up
Just Drive It
Posted 13th Oct 2010 at 15:31
rich-6
Cheers dude, I'l whip mine off and give then a measure now Smile Yup Brembos on the Clio Whistle
Lotek, nail on head. after a while i was thinking surely this makes sense Laugh
Cool
RIP Pete Sims
Posted 16th Oct 2010 at 22:10
Rich E Forum Admin
How similar is the suspension and drive train? Could you use 197 hubs?
Posted 19th Oct 2010 at 19:36
as above, just use 197/200 bits?
actually, if yours is the same hubs as the older RSi's and williams, then they used the same calipers as the 1.9 205 gti, and hence the same bolt spacing, just different discs, which may be your downfall.
Posted 19th Oct 2010 at 22:44
