if i dont see you in the mattress il see you in the spring
| Author | Subject: cam timing |
james_gti6
Senior User Location: Goodwick Registered: 18 Jan 2010 Posts: 528 Status: Offline |
in the middle of fitting the newman ph2 cams today and found who ever did the cambelt before has not timed it correctly, the 10mm bolts are right to the end of the elongated holes in the pulleys, the car seem to pull very well and havnt seen any problems, i will obviously rectify this when i put the new belt on, anybody else had this and was there any difference in power once times correctly. ________________________________________ if i dont see you in the mattress il see you in the spring |
was it just the inlet and was it further forwards?that's called advanced ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
james_gti6
the both pulleys which is the strange thing. i cant remember which way around they are now, i will check in the morning and get a pick up. o do know those 10mm bolts should be central.________________________________________ if i dont see you in the mattress il see you in the spring |
naah, doesn't matter where they are as their position even when pinned up 100% bang on is affected by belt tension.if both are out it may be that the bottom pulley has slipped. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
