Team Nile 6
Team: 40.2 MPG
5 x a 306 owner!
currently abusing type r's in a town near you ™
I truely live for the 306 ®
midweek madness
| Author | Subject: 306 gti 6 hub |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
does anyone know if a hub on a gti 6 would be the same as the hub on any other ordinary 306???? i need a new hub as mine is bent but dont really know where to get one from ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
jim01uk
Seasoned Pro Location: around Registered: 16 Dec 2005 Posts: 8,996 Status: Offline |
need to check it has the right size balljoint clamp hole (18mm IIRC) and that there is a hole for the ABS sensor. |
mattgti6phase2
thanks for the advice. i assume if they are the same as my current then the new one will fit?________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
jim01uk
Yeh can't see why not! |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
get in touch with rolandrat or hanpug25 or pugplus as they may have one lying about, doesnt matter on hub you get just replce the ball joint aswell to suit the hub, there only like 5.50 or something from motor factors, ive got to hubs but 1 has a f*cked wheel bearing!________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
aren't wheel bearings a different size on the base model 306's? Something like 82mm diamater for sports suspension (gti6/xsi etc) and 72mm for others________________________________________ 306 rallye, Richard Longman enginerc10gt |
bar the non abs 1.4 TU's, I believe all the rest are 82mm.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mattgti6phase2
thanks guys. so a hub from a 306 with abs shud be the same fitment?________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
chrisd306
hopefully, try the few guys who break on here.becareful when removing your abs sensor from your hub to fit in replacment hub as normally break, an when fitting the new 1, give the hub a good clean with emery paper an put copper slip on the sensor so it ease'is in. ________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
