thanks
a morgan
| Author | Subject: brake pipe union screws |
a morgan
Newbie Location: shrewsbury Registered: 02 May 2010 Posts: 8 Status: Offline |
i have changed my master cylinder but fluid is leaking from the union screw middle bit where the pipe goes. where can i buy new union screws or do i have to buy the whole lot connection and pipes. but from where?thanks ________________________________________ a morgan |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Will be a new pipe, complet with unions.Some where like parkers can make them up for you |
a morgan
made to measure ok will do. thank you________________________________________ a morgan |
oldbrownshoe
Seasoned Pro Location: Holon Israel Registered: 08 Aug 2008 Posts: 1,795 Status: Offline |
If it's the long pipe that running all the way to the caliper , you better give up.it's just impossible to install it with the engine in place. but there's a way to overcome that without removing the engine. ________________________________________ French military victories?Did you mean French military defeats? |
smegal
Buy measure a route through a hole up to the next connector with a piece of string then get a section of copper brake pipe made up and fit it.________________________________________ Ex SC-6Now in a Megane R26 |
oldbrownshoe
I just ordered to cut in a workshop the new pipe to 3 parts and connect them with proper fittings![]() ________________________________________ French military victories?Did you mean French military defeats? |
oldbrownshoe
It's should be obvious , but worth mention ,the flair in each ends have to be in 37 angle. ________________________________________ French military victories?Did you mean French military defeats? |
