Author Subject: front brakes keep clicking
stevevac43
Hi guys, replaced discs and pads all round and the front o/s.keeps making a clicking/rubbing noise when braking and slight vibraition,its p*ssing me off.had the wheel off more times than i can remeber,even took it to NTS for them to check it but cant find anything,any ideas and help, from you guys.cheers steve
Posted 6th Oct 2010 at 14:26
jon kirby
worn sliders imo, pack them with as much copper grease as you can, should help a bit, otherwise new sliders/calipers or live with it Wink
Posted 6th Oct 2010 at 14:28
lotek
then scream in horror as it runs all over your discs and pads whilst driving, stopping you from braking Yes
Posted 6th Oct 2010 at 14:33
jon kirby
Roll eyes, had worn sliders for the whole 6 years of 6 ownership, dipping them in copper grease every pre mot helped with the fact they were worn, the rubber boots then covered them, not once did i have an issue with grease covering either the disk or pads, but then having 6 years of 6 ownership and doing all the work myself clearly means i am a know nowt meff Whistle!
Posted 6th Oct 2010 at 15:31
lotek
nowt meff? Huh? WTF is that? LOL
you had it for 6 years and you diddnt put new calipers on it? shame on you LOL
pre mot bodges are pre mot bodges. but on a daily driver i wouldnt be doucing my brakes with copperslip, id much rather put new calipers on Roll eyes
Posted 6th Oct 2010 at 14:57
stevevac43
Cheers guys. I will put some copper grease on it see If that helps it. And I will replace the calliper if I need to. Cheers.
Posted 6th Oct 2010 at 15:14
jon kirby
WTF! lubing the sliders is something i always do, prevents seizing didn't you know, i arn't saying slap it on all over, but i found applying the grease liberally on the sliders helped with the rattling issue quite alot. Either way my bodging must have been pretty special as in the 6 mots i put it thru it only ever failed twice, once on a fooked lambda, and the other time it sheared a hand brake cable during the test.
Posted 6th Oct 2010 at 15:30
