Author Subject: 6, top end rattle
ash306gti6
hi all...
my 6 has developed a severe top end rattle, severe lack of oil getting to the top end yet oil pressure seems fine.....
any thoughts please people
Posted 5th Oct 2010 at 00:40
309btcc
**DODGY SELLER**
is it when hot or cold?? and did it come all of a sudden??
Posted 5th Oct 2010 at 00:46
ash306gti6
yeah was driving not hard, stopped the car restarted it about 10mins later and it rattled its tits off :/ wsa warmish then i guess and defo does it from cold 2
Posted 5th Oct 2010 at 00:48
309btcc
**DODGY SELLER**
u checkd oil may be low or needs a change or a stick lifter stick sum engine flush thru it drop the oil then put sum good semi in it..
Posted 5th Oct 2010 at 00:52
ash306gti6
oil was spot on the money, just had a full sevice less that 1000 ago. removed the rockers and there is oil starvation to the top end for sure
Posted 5th Oct 2010 at 00:55
309btcc
**DODGY SELLER**
sounds like it maybe the oil spray bars then get a airline and blow them thru and clean them with brake cleaner
Posted 5th Oct 2010 at 00:57
ash306gti6
inspected and cleaned them lol all clear and spot on hence why im starting to scratch my head :/
Posted 5th Oct 2010 at 00:58
What make filter did you use?
I would change that,as its easy and cheap to tryWink
Does your low oil pressure warning light go out as normal when you start car?Unsure
Have you re-sealed anything on engine using gasket sealer recently? Ninja (sump/cam covers etc)
Posted 5th Oct 2010 at 02:13
ash306gti6
It had a genuine oil filter, i personally havent resealed anything but havent long purchased the car :/ Oil light goes out as should when started..... would severe head gasket failure cause this problem if excess oil is going into water?
Posted 5th Oct 2010 at 16:09
Rich E Forum Admin
The head has a one way valve on it's oil feed that stops the oil draining out of the head when the engine is off. It's been known for this to clog up and starve the head of oil.
It's a head off job to sort it out unfortunately, but it's worth trying some engine flush to see if that cleans it out.
Posted 5th Oct 2010 at 16:46
midlife
Mine sounded like a severe top end rattle when it was actually a spun big end bearing..
Cool
Team 330™Cool
Team "no front end or engine"
Posted 5th Oct 2010 at 17:02
Rich E Forum Admin
Yeah, mine too, although you'd expect to see oil pressure and temperature issues (along with crap running!) with a spun bearing.
The normal oil pressure, the OP's observed oil starvation in the head and the lack of mention of any other running issues suggests the bottom end is okay.
Posted 5th Oct 2010 at 17:27
cwspellowe
I once had a loud top end rattle after a spirited drive, thought the belt had slipped a tooth or something but it disappeared after a couple of easy miles later Dunno
Probably oil starvation or something but not a peep out of it since
Bye bye Sundance Kid Sad
Posted 5th Oct 2010 at 17:30
ash306gti6
Yeah def got oil starvation 2the cam's, sounds like i'm gonna b whipping the head off then, is it a case of just cleaning the one way valve if clogged?
Posted 5th Oct 2010 at 18:04
mechanical_repairs
Best to get a new one, get a sizeable self tapper and screw it into the valve then pull it out with pliers, this will then remove the valve from the head.
Normally you will find paper from the oil filter clogged up in there, pain as to fix the problem will take minutes it's just the heart axe to get to it.
Carl
Posted 8th Oct 2010 at 02:54
james_gti6
sling this in LOL
if i dont see you in the mattress il see you in the spring
Posted 8th Oct 2010 at 03:14
ash306gti6
ive got it semi stripped so just gonna rip it apart on saturday and go from there... may as well do a rebuild whilst im at it and go to town.... alot of hassle just for one poxy valve grrrrr so may as well tweak a few bits whilst its apart Smile oh how i love cars..... ha
Posted 8th Oct 2010 at 15:36
ash306gti6
stripped the head off to find the one way valve to be clogged up with what looks like an old piece of gasket grrrr, still problem solved hopefully, head to be sent off for pressure test and a skim then refit it all back together and hopefullly happy days
thanks for your input those that have commented with suggestions....
I will update once refitted but fingers crossed Smile
Posted 12th Oct 2010 at 15:30
