Author Subject: broken wheel bolt
jimbobewob
hi as the title says i have sheared off one of my front drivers side wheel bolts.when i finally got the wheel off i saw it is flush with the disc.how do i remove?can i take the disks off to get a bit more bite or do i remove the whole hub?and how do i do it any help much appreciated thanks james.
Posted 4th Oct 2010 at 23:26
smithers
Yeah take the disc off and you should be able to get a pair of mole grips onto it Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 4th Oct 2010 at 23:29
chris with a pug
you might even be able to unscrew it by hand as all the tension from the bolt will be gone
Posted 5th Oct 2010 at 01:40
bounty37
You can get something called an ez-out. You drill a small hole in the center of the sheared bolt, insert the self tapping bolt into the hole in a left hand thread direction and then as you tighten it removes the old bolt.
Get them from Screwfix
http://www.screwfix.com/prods/18643/Drill-Bits/Specialist-Drill-Bits/Screw-Extractor-Set
Simples
Posted 5th Oct 2010 at 02:47
tvrfan007
It should unwind as it's carrying no load now. Take the disc off and get mega moleys on it.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 5th Oct 2010 at 13:52
jonnie205
they dont wind out, you will be easier buying a new hub, the reason it snapped was due to it seizing up, have got one out before but was welding and heat etc
Posted 5th Oct 2010 at 13:59
Depends whether it sheared when tightening or untightening. If it was overtightened it should be loose now.
Won't know til you try Smile
Posted 5th Oct 2010 at 14:48
I managed to drill it out and get some of the thread cleaned out just enough to re-tap.
Posted 5th Oct 2010 at 16:33
cooper666
dont use a easy out when they snap your fubaredSad
clio r27
ps3 id:cooperkloe
Posted 5th Oct 2010 at 23:54
