BHARVEY
| Author | Subject: gti6 mi16 |
pugben
Newbie Location: folkestone Registered: 11 Feb 2010 Posts: 8 Status: Offline |
Hi is the inlet the same on a gti6 as mi16? do the manifolds swap over, studs in same place? cheers________________________________________ BHARVEY |
no not the same.yes it will fit, lots of messing about with the pipework though. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Keep the s16 avac inlet.When its correctly set up and working correctly it very good |
pugben
after putting carbs on a gti6 lump have seen a manifold for an mi16 just wanted to know if it would fit ________________________________________ BHARVEY |
dont put carbs on it, they're crap ![]() T-B's and management or nowt! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugben
engines not in a 306 its in a 205 have run carbs for years with no probs and with an impressive power figure and soundtrack________________________________________ BHARVEY |
rallyeash
ignition ecu FTW then.. ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
pugben
just wanted to know if inlet was same as mi16?________________________________________ BHARVEY |
rallyeash
no________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
miles
Yes the Jenvey inlet is the same on any Pug 16v XU engineFitting carb's thou I doubt will gain any power or torque as the std inlet is very good, but will sound better ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
monty-69
Senior User Location: Colne Registered: 02 Jul 2006 Posts: 792 Status: Offline |
You will see similar power/torque increases to fitting throttle bodies if set up correctly. |
pugben
my 205 is running carbs at present on 8v so will just swap it all over to 16v lump with new inlet manifold saves messing with all the wiring________________________________________ BHARVEY |
I'd rather mess with the wiring (4 or 5 wires to make it run btw...) than run carbs.last gti6 engine I heard of running carbs made 170 bhp.... ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugben
more than current 8v !________________________________________ BHARVEY |
miles
But the std 6 engine makes only a couple less and hence my comment really, The wiring or if someone did a plug and play loom would be cheaper than setting the carb;s up again, Unless you can DIY them And to further on the inlet's, only buy the Jenvey one, others can be had £20 or £30 cheaper but you'll spend allot of time making them fit ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
