dont lift just drift
| Author | Subject: s16 hesertating between 3000-4000 rph |
orvill
Newbie Location: aberystwyth Registered: 24 Mar 2008 Posts: 40 Status: Offline |
hi.... need some help... bought an s16 m plate 1994 peugeot 306 the car was running fine,, been parked up for about 6 weeks put it on the road today and it is hesertating between 3000-4000 rpm.. also it is a bit lumpy on start up.... only for 30 seconds or so then fine... revs ok on tickover... ive put some injector cleaner in to see if that will help...? could it be plugs?? the only thing i have changed is the air filter,, put a k&n on instead... ________________________________________ dont lift just drift |
tarret
Regular Location: Maidstone Registered: 27 Sep 2009 Posts: 323 Status: Offline |
hi i had simular type of problem it turned out to be a green sensor just in front of the thermostate, sorted that out and now starts fine |
orvill
was it heasertating between 3000-4000 also??? ________________________________________ dont lift just drift |
tarret
only on cold start up, once it had warmed up it was fine |
snillet
Newbie Location: Ytterby / Sweden Registered: 06 Apr 2010 Posts: 47 Status: Offline |
Inlet diaphragm actuators working like they should?If not itīs problably more more less "dead" between 2500 and 4500rpm. Quite common on these old cars these days. Diaphragms are available from Peugeot though. Donīt know cost where youare but here in sweden theyīre about 65Ģ for one. They usually last something like 5-10years of normal service so i do not consider that to bad myself. ________________________________________ Member of Peugeot Sport Club Swedenhttp://www.peugeot-sport-club.com/ My son: http://www.youtube.com/watch?v=jzjSBKkMHDA |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
As said could be a faulty or incorrectly adjustd diaphram.Split pipe on the avac system. |
