displaying posts 26 to 29 of 29
Pages (2): 1 [2]
Author Subject: How To Rotate Camshaft On Bench?
rich306
Sounds like a delicate process, i've got this all to come!
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 4th Oct 2010 at 11:54
mikebee
mabgti wrote:
always time the cams off the block on the rfs head.. the valves tend to pinch and bend causing the slight tap.. be careful when you use the locking pins, making sure they are a snug fit... dont be tempted to use allen keysNo
strap wrench the exhaust cam first, then the inlet.. this should leave enough clearance for timing the inlet.. make sure pulley is flat on the woodruffYes
I am still unsure about this. It seems half people say lock the cams on the bench and half say on the car. The Peugeot manual says on the car and this makes sense to me to avoid potentially 'knocking' valve heads putting it on the car.
I'm confused Sad which way is best???
Posted 4th Oct 2010 at 13:56
mabgti
NV motors
follow carl as he has tap less heads... follow me if you have genuine head locating rods!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 4th Oct 2010 at 22:52
ryangti6
I would pin it first everytime just so you can see what you are doing.
Just be carefull when placing the head that you dont catch the open valves on the top of the block.
Also to add that having played with a good few of the Rs heads it does sound like something isnt quite right with the amount of force you say you need.
If I was you I would take the carriers back off and start the assmebly again, they really shouldnt be very difficult to turn with a socket or spanner.
Ryan
Posted 5th Oct 2010 at 00:03
Pages (2): 1 [2]
