Author Subject: Braided hose length - Goodridge
deanstacey
Having had a bit of a nighttmare with brake hoses, thought I'd just flag this up.
The lengths of hoses on my Rallye are:-
Front 530mm
Rear N/S 190mm
Rear O/S 235mm
The goodridge set I purchased had 2 fronts at 530mm and 2 rears at 190mm
The kit purchased was GDRSPE0902-4C which is for 97 onwards with discs.
Looking on the forum this is the correct kit, there is a picture of hoses in a clear box that seam to have two different length rears and people have fitted Goodridge hoses with no problems. But Goodridge say that their kits only come with matching rears so their seems to be some confusion
This has meant that I've had to send the short one back to GR and they are going to produce me a longer one at trade.
So, my advice it to measure your hoses before you order and make sure the ones you are ordering are the correct lengths!!
Posted 1st Oct 2010 at 23:29
mr swampy s16
**BAD SELLER**
The set i supply come with different length rears
Posted 1st Oct 2010 at 23:38
your kit is for a phase 3 with EBD.
Posted 1st Oct 2010 at 23:43
deanstacey
Sorry for being ignorant EBD?
Posted 1st Oct 2010 at 23:50
Rich E Forum Admin
Electronic brake force distribution.
Phase 3s don't have the load compensator which is why they don't need one of the brake lines to be longer. The brake force distribution is controlled by the ABS unit instead.
Posted 1st Oct 2010 at 23:57
deanstacey
Thanks Rich.
So basically if you have a phase 3 with EBD this kit will fit, if you have a phase 2 with a load compensator, then you need to check before ordering.
Posted 2nd Oct 2010 at 04:50
