Author Subject: I need some help!!!! :angry
tabbbster
I have a annoying squeek from the front right wheel area.
Its a rotational sqeek its there when the engine is off and the car is coasting.
Its only there when going in a straight line if you turn the wheels it gets less or goes away.
There is no bearing rumble from the wheel bearings.
Also the drive shaft in that side was changed as the intermediate bearing had gone so I replaced the whole thing.
The front brakes have been stripped and rebuild and lots of copper slip an them.
So I am slowly runnig out of ideas as to what it could be???? My only option is to strip that side down and see if i spot anything. Sad
Anyone had something simular??
My Rallye was built on thursday 7th January 1999 according to the cosmic code generator.
My Cyclone refurb
Posted 1st Oct 2010 at 23:01
still could be a wheel bearing Smile
Posted 1st Oct 2010 at 23:11
tabbbster
Thats what I think but the garage kept telling me not. Maybe I'll just do it this week. Dry
My Cyclone refurb
Posted 1st Oct 2010 at 23:13
Not the tyre rubbing on the strut is it?
Posted 3rd Oct 2010 at 00:31
tabbbster
na the tyres fine. Sad
My Cyclone refurb
Posted 3rd Oct 2010 at 00:57
tabbbster
I fixed it in the end with some spray grease and i think the bearing was ever so slightly loose. So I tightened it a bit. No Squeeking any more. Smile
My Cyclone refurb
Posted 29th Nov 2010 at 22:08
lotek
tightened it? if its a wheel bearing you cant tighten it, its a sealed bearing unit Yes
all you have done is put more pressure on bearings , it will wear and develop more play soon enough Yes
id get a new bearing pressed in .
Posted 30th Nov 2010 at 19:43
tabbbster
The thing is I did have the bearing loosened off for the driveshaft to be replaced. There was no play before this. So I may not have tightened it enough. The only time it made a noise was on strights and none on cornering. The noise was the brakes rubbing. Its been OK now for 2 months. I have the new bearing if it goes wrong so I just play the waiting game. All of the wheel bearings have done 116000 Miles now. Smile
My Cyclone refurb
Posted 1st Dec 2010 at 03:45
