Author Subject: Unlocked ecu (which pins nees to cut)
eric.
Hello! I have unlocked ECU. Which pins do I need to cut?
Can I then remove the ECU from the car as many times as I want?
ThanksRazz
Posted 30th Sep 2010 at 19:39
paul_13
Take the halo out from around the key and the immobiliser box.
WP should know where these are located, what phase 306 you have?
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 30th Sep 2010 at 19:45
eric.
Ph2
Posted 30th Sep 2010 at 20:47
