Author Subject: loose ecu+bits unlocking?
snillet
If i have the following parts(which i will have soon):
ECU+engineloom+loom inside with transponder+key with chip.
If i plug this together providing "ingition on" state, and then unplug the ECU, will this "unlock" it?
I will use this loom and ECU in another car but want to get rid of the immobilizer "stuff".
Iīve caught up on the "cutting off the transponder" part once the ECU is unlocked and all that.
What i want to know is, can i unlock the ECU even though itīs only connected to the transponder and "powered up", or do i NEED to wire it up to all the enginesensors also?
Member of Peugeot Sport Club Sweden
http://www.peugeot-sport-club.com/
My son: http://www.youtube.com/watch?v=jzjSBKkMHDA
Posted 29th Sep 2010 at 17:09
Rich E Forum Admin
Ignition on is sufficient. You don't need the sensors.
Posted 29th Sep 2010 at 18:18
snillet
Which means what i wrote "should" work?
Happy me Big grin.
Posted 29th Sep 2010 at 19:42
snillet
BTW... is there any indicator i can meashure when doing this to see that the box has really "unlocked" ?
Posted 29th Sep 2010 at 20:05
snillet
What is the function of the speedsensor?, what happens if i do not connect one? I would imagine that those who transplants this system into a 205 doesnīt use it?
Posted 11th Oct 2010 at 00:43
mabgti
NV motors
you'd be suprised.. the VSS does make a difference to engine performance..
i'm sure there is a compensating map as the inlet was made with forced trunk design!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 11th Oct 2010 at 04:52
snillet
Yes, well, thereīs not much work involved in using it, i was just curious :-)
Posted 11th Oct 2010 at 22:46
