Author Subject: URGENT PLEEEASE HELP
JWP EFi
Turbo Legend!
Since changing the clutch/disconnecting the battery on my 6, i have had a rather erratic idle, before i go any further, she only does it when temp gauge is 80 degrees and above.
The revs are hunting between 850 and 2200 rpm and when changing gear the revs 'hang on'
Firstly i did the usual check and clean the stepper motor and check for vacuum leaks
then i bent over and got shafted £90 for new stepper, reset ecu and still no joy.
i replaced the ecu coolant temp sensor, reset management, problem still remains
Lastly, i had a diagnostic check and they could not find any faults, they told me as the ecu is self learning, then i should put some more miles on it and it 'should' cure itself. I have done exactly this and guess what, problem is still there.
what puzzles me is, the car was running sweet before i disconnected the battery, i would also like to add that i have had this prob on a few XSi's ive had and usually once the stepper and housing has been cleaned the problem disappears
Anyone any ideas???
Posted 26th Sep 2010 at 00:25
cd52
Have you disconnected the battery again yet?
Posted 26th Sep 2010 at 00:32
JWP EFi
Turbo Legend!
yes i have disconnected / reset ecu several times, problem is still there
Posted 26th Sep 2010 at 00:37
cd52
How long are you leaving it disconnected for when doing this?
Posted 26th Sep 2010 at 00:40
JWP EFi
Turbo Legend!
around 10 mins, done this before and as i said usually cures fault
Posted 26th Sep 2010 at 00:44
cd52
I would try leaving it off a bit longer. 30mins to an hour and see if that makes a difference.
Posted 26th Sep 2010 at 00:46
JWP EFi
Turbo Legend!
i will leave it unplugged over night, i do remember trying this before on another pug, thanks for advice though
Posted 26th Sep 2010 at 00:52
JWP EFi
Turbo Legend!
just a thought. my engine's wiring loom is now 13 years old, when i changed the clutch i obviously had to move the wiring out of the way, i mean lets face it its not exactly 'roomy' in a 6's bay
anyway is it possible that the wiring may be slightly corroded due to age and then with me moving them about i have damaged a wire???
Posted 26th Sep 2010 at 01:18
