| Author | Subject: IAT, MAF and O2 sensors on a 6 |
mightyjoe1
Newbie Location: Sydney Registered: 25 Sep 2010 Posts: 4 Status: Offline |
Could someone please help me identify the IAT, MAF and O2 sensors on the 6? If anyone has a picture that would be great. Have looked on other threads but can't find any help. |
there is no MAF.check the FAQ section ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
It uses a MAP sensor and an IAT sensor to calculate the mass of air going into the manifold.________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
mightyjoe1
Arrh righto, well which sensor on the intake is the IAT? |
mabgti
back of the throttle body... grey sensor. two wire plug.________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
mightyjoe1
Fantastic, I am hooking up a chip and it needs to connect to iat and maf. So would I just hook it up to the map sensor seeing there's no maf? Thanks for your help |
mightyjoe1
Sorry bout all the questions really need to get me a Haynes manual. Just checking that the map sensor is the one with the extra pipe connected to the intake, and also do you knowwhich wire on the iat is the signal wire?? |
jcphat
Seasoned Pro Location: In the day room, Nurse! Registered: 22 Feb 2008 Posts: 1,061 Status: Offline |
What sort of chip is this you are fitting? The one with the "extra pipe" is the stepper motor or ICV. It sounds like you are doing something you don't understand with an e-bay chip which promises extra horsepower. You need to be sure it is compatible with your electric supercharger.________________________________________ New Forum same high quality intellectual debate!Team Zimmer™ |
nooooooooooo!!!!!!!!!!!!!!!!!!!!!!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
beez_neez_gt
MAF is the mass air flow, same thing different name for it isnt it?________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
what?!There is no MAF on a gti6 MAF = ![]() why did you bump a 3 year old thread? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
beez_neez_gt
Searching, what is it with people and old threads, by making more new ones just fills forum with to much info.Yes i see now, MAP manifold absolute pressure . So looking at the picture the MAF looks like a two in one sort of sensor ?? ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Some read a lot of data such as intake air temp, airflow rate and barometric pressure all in one unit.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
