Author Subject: Engine Cuts out. Help Please
chris_1389
I have a problem with my 306 1.6 lx year 2000.
The car will start fine in the cold and move away. when i come to a junction, go to put my foot on the accelerator the engine gives a little splutter and then cuts out. (it's not me stalling the car before anyone mentions that)
It then takes a good few tries and a lot of cursing to get it going again. This can be a pain when at a busy junction.
This problem occurs for the first 5 minutes of driving and when the engine is hot its fine.
The problem is none existent in the summer but has started to play up again now its getting colder.
The only way to avoid the problem is to keep the revs up when the clutch is in. (not ideal i know)
Any help anyone could give would be greatly appreciated.
Posted 21st Sep 2010 at 15:20
mabgti
NV motors
sounds like a failing lambda sensor.. or be it the heater element... as once its up to temp... 600deg it works fineYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Sep 2010 at 05:43
chris_1389
Thanks will have a look at these this weekend
Posted 22nd Sep 2010 at 14:26
chris_1389
i have managed to fix this one i replaced the battery after it died during the frost and this seems to have fixed the problem
Posted 18th Jan 2011 at 18:58
