Author Subject: Converted to gti??
krisb
How have people managed to install the lift up reverse? In the middle of coverting an xsi to gti, is it as simple as drilling a hole in the bulkhead?
www.krisb.co.uk
Posted 18th Sep 2010 at 20:38
rich306
i didn't think you had to drill any holes Kris, i thought it was a straight forward swap the gear linkages and strut straight over?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 18th Sep 2010 at 13:31
krisb
Well the linkages including the bar and the 6 speed lever are all getting swapped over. The gti6 has got a lift up reverse which is operated by a cable from the gearstick to the top of the box.
www.krisb.co.uk
Posted 18th Sep 2010 at 17:49
jonnie205
drill o hole in bulkhead to run the cable, plus you will need a gti6 gear stick
Posted 18th Sep 2010 at 20:39
krisb
Nice one cheers, i've got a complete donor car Smile
Some of you might recognise it...
www.krisb.co.uk
Posted 18th Sep 2010 at 20:53
birk
I just drilled a hole, easy!
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 18th Sep 2010 at 21:29
