Author Subject: airbag light problem and dodgy speedo
colsim06
hi peeps i was just wondering if anyone could help,basically my airbag light on the dash keeps flashing on and off constantly and was wondering why it wont go off? :/ also the past couple days my speedo decides to pack up occasionally and starts to work again after a while,its soo annoying wen driving near speed cameras etc,what could this be ?
Thanks
si
Posted 16th Sep 2010 at 07:24
The Airbag light is on because there is a fault somewhere,
the most common problem is a loose connection somewhere a popular one is under driver chair
this may only apply to P3's though just make sure everything is plugged in and secure!
if your not sure what your doing get it to someone who knows what there doing,
as for the speedo
this can happen for a couple of reasons
they work by receiving a signal from your ecu
mine went funny due to a break in a wire by the bottom of the bumper
but commonly it's just the silver (metal fuse) under your steering column picking up static iirc
just take it out give it a wipe and put it back
Wink
Posted 16th Sep 2010 at 07:40
colsim06
ok thanks for that mate will have a look at it today Smile
Posted 18th Sep 2010 at 15:00
jammamayhew Banned!
I have same problem, loose connection under the passenger chair in my ph3. Sometimes I can sort it, then if the chair is moved or sat in it can come on again.
What I'm going to do is because I know its just a dodgy connection and the airbags should work fine, I'm going to take the bulb out from the airbag light in the dash. That will stop it going off Smile
I've been told it will still get through an MOT too Smile
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 19th Sep 2010 at 19:01
just fix it properly, it'll take less time than taking the dash apart.
you'll get a new username with that attitude,
jammabodgermayhew Razz
Posted 19th Sep 2010 at 19:22
jammamayhew Banned!
I have enough nicknames already, you think I care? lol
I thought it would be easier taking dash out than it is the chair as I'm looking to upgrade the dials with some white bulbs instead of the yellow older bulbs.
NUTRI-FIX
]FOR SALE[/b]
Posted 19th Sep 2010 at 19:30
its just an iffy connection under the seat, 5 minutes with a soldering iron.
Posted 19th Sep 2010 at 19:38
there's also the issue of if your Airbag system develops a serious issue that may stop your airbag from working and you'd never know about it!
at the end of the day it's there for your safety just sort it properly it's the best way Yes Wink
Posted 19th Sep 2010 at 20:15
jammamayhew Banned!
I suppose I could work on my soldering, last time wasn't very good so a bit of practise on a single wire shouldn't be a problem. lol
NUTRI-FIX
]FOR SALE[/b]
Posted 19th Sep 2010 at 20:38
colsim06
ive managed to sort the airbag problem now,was a dodgy connection under the passenger seat lol.gonna have to take the car to the garage tho about the speedo,works most of the time bt occasionally stops and is very annoyin,1 of the common faults apparently :/
Posted 20th Sep 2010 at 05:21
jammamayhew Banned!
Also sorted mine out just this minute, took me 2 mins. I just removed the yellow plastic block bit and just connected the wires again and they are firm enough so didn't need the solder out Smile
NUTRI-FIX
]FOR SALE[/b]
Posted 20th Sep 2010 at 23:19
I hope I'm reading this wrong? You've removed the connectors and just intertwined the wires together? Similar to this.
If so at least get some electrical insulation tape around them.
Posted 21st Sep 2010 at 05:37
smegal
Pull out the solid metal (maybe opaque green plastic) fuse and leave it out for a few minutes.
Just make sure you have your radio code.
Ex SC-6
Now in a Megane R26
Posted 21st Sep 2010 at 17:24
jammamayhew Banned!
Na looks nothing like that!LOL
Basically theres a female yellow block holding one wire with a female end connected that is stuck to the chair, I've left that how it is. Then there was a male yellow block that clicks into place in the yellow block which had the other wire with male end bit. I have removed the male yellow block only.
The wire still connects to eachother securely, and theres now just the 1 female yellow block that gives them a bit of protection and keeps them securely stuck to the chair (not hanging).
Hope this explains it a bit better, not sure if ph3 have differenct connections under the chair to others but dont have any pics
The yellow blocks are similar to the ones found that connect the front door speakers.
The wires look similar to this but with just the female block around them
NUTRI-FIX
]FOR SALE[/b]
Posted 22nd Sep 2010 at 00:26
