Author Subject: advice on fitting an amp
loftlex
Hi
I am new to this forum
i have fitted many diffrent amps to all diffrent types of cars in the past,
my question is how the hell do i run the power cable from the battery in to the car, there are no obvious grommets to move,
reading on the net i get mixed answers, some say there is a grommet,, others say just drill and seal,
i bought this little 306 just because i have never owned one before, and it was a cheep little run around
its a 1998 td
any help would be great
GTI wanna be Sad ---In a puff of black smoke and a whistle,,, i was gone Smile
Posted 14th Sep 2010 at 13:23
jon kirby
Is it a 6? if so there is a huge grommet in the pass side footwell to allow the air con pipes thru the bulkhead. I used this, it's a bugger to get to but perfectly placed for a route to the battery.
Posted 14th Sep 2010 at 13:35
loftlex
hi, not as far as i know, i am new to this so forgive my ignorance, its a 1998 td
Posted 14th Sep 2010 at 18:53
dragoon
there is a grommet above/behind the master brake cylinder
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 14th Sep 2010 at 21:48
paulvt
depends on the size of the cable i believe as i am running 4awg cable so have run it under the car and into the boot
allesclar wrote: wrote:
the only kind of similarities of the xsi and a 6' is if you jumble the letters round to spell six Razz
Posted 14th Sep 2010 at 23:07
anth
Yes the gromit next to the MC is handy you can get a 4 awg cable down that easily. f*ck running it under the car. I can take a picture of it if required.
Posted 15th Sep 2010 at 16:06
loftlex
thanks for all the info, anth, any pictures would be great Smile thanks
Posted 16th Sep 2010 at 03:22
x m ii k e x
I've got a 1.4 95 Sad lol but I drilled through under the glove box and sealed it. Works fine and no water leaks.
Posted 8th Oct 2010 at 00:11
loftlex
have a look at this
the bloke said to drill a hole in the red circle..
but the drain plug to the left leads straight in to the car
why not just put a hole in that and feed the wire through it?
has anyone tried doing it this way?
loftlex has attached the following image:
Posted 19th Oct 2010 at 18:12
loftlex
or has anyone got a picture of the grommet near the brake bit,,, i cant get my amp working Sad
Posted 20th Oct 2010 at 20:43
