displaying posts 1 to 2 of 2
Author Subject: car handleing problems
eggman
put my car on the lift the other day and found i had a lot of play on the drivers side hub... bought a new ball joint and the problem is still there,,,, the play is only left to right not up and down,,,,,,
can anyone help me,,,,, cheers
Posted 14th Sep 2010 at 01:36
Its probably been damaged. If you don't sort out the issue early enough they tend to go oval and the balljoint will then never sit right in the hub.
The only other thing it could be is that you've got a 16mm balljoint in an 18mm hub.
Posted 15th Sep 2010 at 14:32
