Author Subject: Grille not fitting properly
burnout21
I managed to get myself a set off Crystal's for my Phase 2 this weekend, really cheap. They was off a phase 3 convertible. I have fitted them today, but it seems I haven't done something right because now my grille will not sit right. I've had to push it in a bit so that I can get the latch bolt in, but now the grill is bent slightly so it's curved underneath. Huh? I would have thought the lights on a convertible would be no different. The Grille would not bend or struggle to get Latch bolt in when I had my phase 2 lights on. Any advice appreciated Smile
Posted 12th Sep 2010 at 21:52
Should do they are the same. Have you tried removing everything and having another go?
Was everything removed on the inner mounts from the slam panel and the old set of lights as there is a slight difference in the lugs iirc.
Posted 12th Sep 2010 at 22:51
burnout21
I'm not sure if it could be the adjusters. a plastic screw thing. my old lights only had 1 in. but fully screwed in. behind the lights,all was removed. may have to have a look tommorrow night. just bugging me that its not sat straight. and the fact it is tight. am impressed tho. does look better now Smile
Posted 12th Sep 2010 at 23:29
