Author Subject: 306 HDI
steven gti
Hi boys, my 306 hdi keeps cutting out now and again engine management light on any ideas?
Posted 6th Sep 2010 at 00:06
tvrfan007
It could be any one of 50 things tbh, you'll need to get the fault codes read. There are plenty of people on 306.net who can do it. I'd offer to help but you're about 400 miles from me. Razz
If it's cutting out under load i'd suspect a lazy in tank lift pump but codes will return fuel pressure problems. If it is the in tank pump, take it out and see if the filter sock is clean before getting a new one - you can get to it under the rear bench.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 6th Sep 2010 at 00:53
steven gti
ye i was thinking it was some like that in tank pump. used to hear it loud before startup now its queit. ill get the fault codes and take it from there
Posted 7th Sep 2010 at 00:11
asim_pug306
I'd bet on it being the high pressure pump or the high pressure pump regulator. Happened to me a number of times with my HDi. If it's the regulator, I'd replace it with a brand new one.
I bought a second hand pump with the regulator from a scrapper and the problem re occurred. Try not to run the diesel too low into the reserve as this is what usually causes te problem.
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 9th Sep 2010 at 02:26
