Author Subject: Bike Bodies
anth
I know there is a fair amount of threads relating to this already but I'm after some opinions.
Is it worth doing or is it a waste of cash?
Using the standard ecu and making a plenum for the MAP and ICV basically like the project that Yanni done. Although it has not been updated for some time.
I just don't want to pull my car to pieces get it up and running pay for it to be mapped and it ends up being shit LOL
I have run some before on an omex 600 but the bodies were too small i think so it went back to standard.
Is it worth a punt or shall i just save my cash?
Posted 5th Sep 2010 at 23:09
worth doing only if you get a decent inlet manifold and throttle linkage done, and a proper map on the ecu.
Posted 5th Sep 2010 at 23:16
rallyeash
is worth doing, as above get a decent manifold for itSmile should be a fair bit of info on here about the best tb's to go for
309 3dr K20 Type R
Posted 5th Sep 2010 at 23:17
anth
Yeah,
ecu would defiantly be mapped.
What could be wrong with a throttle linkage?
Inlet manifold, I guess its just a cut down standard job. Then extend the length between that and the butterfly with hose and solid inners.
Where do you get said manifolds?
Posted 5th Sep 2010 at 23:19
ryangti6
The throttle linkage needs to be modified between the bodies as on Yanni's thread, if this is not done correctly then the butterflys wont open together, there is a bit of adjustment to but it needs to be done well to be able to get them perfectly balanced.
Also you need to modify the throttle quadrent ideally or your accelerator is going to be like an on/off switch.
Manifold you will need to make yourself unless you are lucky enough to find one already done. To be honest though Imo you would be better off making one or getting one made from scratch than cutting a standard one down.
Ryan
Posted 6th Sep 2010 at 07:00
maz-306-xs
I'm halfway through making my own set, following yannis thread. I'm realy hoping that everything goes smoothly. I'll let you know how it goes.
banned for drifting. back in the s**tbox scene.
Posted 6th Sep 2010 at 07:24
if you make the throttle linkage and quadrant properly there's n need for any pedal mods.
Posted 6th Sep 2010 at 13:55
rallyeash
or just buy a proper jenvey setup, no feking around then Smile
309 3dr K20 Type R
Posted 6th Sep 2010 at 22:16
no fecking around with bike bodies if you get someone else to do the machining and fab Razz
Posted 6th Sep 2010 at 22:59
ryangti6
Is it still cost effective then though
Ryan
Posted 6th Sep 2010 at 23:36
