Author Subject: temperamental rallye!!!! please help
bigandy
ok heres the problem.
my rallye decides when it does and doesnt want to start!!!
doesnt matter if cold or just been running.
fuel pump primes every time.
just changed crank sensor.
done ecu reset
turns over and over
some times she'll start first flick of the key others i can be trying for 5 mins before she finally comes to life and then she'll run sweet as a nut.
the last few times its led me to thinking fuel? because she turns and turns then coughs and starts, fuel relay????
the fact she runs fine once she starts rules out sparks and coils right??? please help cheers
Posted 4th Sep 2010 at 04:00
CUJ
Deffo sounds fuel related to me too, have you tried swapping the fuel pump relay yet?
How old is your battery?
340 horses
Posted 4th Sep 2010 at 04:04
bigandy
not yet, just setting up a "to test list" for the morning. if it was the fuel relay would the pump still prime?
Posted 4th Sep 2010 at 04:05
bigandy
not sure age of the batt but she'll turn and turn till the cows come home so thats ruled that one out for me.
Posted 4th Sep 2010 at 04:06
CUJ
Does it tick over normally ie with no dodgy noises?
340 horses
bigandy
yeah fine.
Posted 4th Sep 2010 at 04:09
check for power at the coil packs and injectors and if you do check for a spark when it doesnt want to fire.
Posted 4th Sep 2010 at 04:14
bigandy
ok cheers, if i find no power or spark then wheres the problem lie?
Posted 4th Sep 2010 at 04:16
dan_s16
IIRC a dodgy cam position sensor can cause issues like that.
Posted 4th Sep 2010 at 04:18
bigandy
wheres that live?
Posted 4th Sep 2010 at 04:23
CUJ
It's the blue electrical sensor on the inlet manifold. Thinking about it, if the fuel pump is priming ok, it's more likely spark related as opposed to fuel.
340 horses
Posted 4th Sep 2010 at 04:41
pug-gti6
Dodgy Immobilizer?
Posted 5th Sep 2010 at 04:04
Cam sensor for me too, top left side of the engine, near the cambelt cover, blue sensor, three pin plug....
Be prepared though, they are about £115 from Pug. Sad
Stan.
Posted 6th Sep 2010 at 12:47
