displaying posts 1 to 2 of 2
Author Subject: Gti-6 Miss fire? only for ¼ mile?
ctu stu
Mate of mine also has a 205 with a Gti-6 engine and his has bit of a miss fire? when its started in the morning it ticks over fine but for the first ¼ mile it runs on 3, Could this be the coil pack? are they easy to change?
Posted 3rd Sep 2010 at 19:42
cwspellowe
Could be, or it could be early signs of a head gasket failure while it dumps the coolant out of the cylinder.
If you're worried check for smoke/steam from the exhaust, coolant levels and possibly a compression test.
Or it could be one of the coil packs, the gti6 uses four separate ones as opposed to one coil pack and HT leads. Unplug them one by one to see which one doesn't make a difference, if having one disconnected doesnt affect how it runs you know its a dodgy one Smile
EDIT or possibly the lambda sensor if it only does it when cold
Bye bye Sundance Kid Sad
Posted 3rd Sep 2010 at 23:32
