Author Subject: New Drive Shaft Knocking?
jamanna85
Hi can any one help
I`v rebuilt a S16, Engine/box/suspension/drive shafts and here`s where the problem is two recon drive shafts offside is fine but nearside knocks (when turning right)I have even exchanged it for another new one and it still knocks?
Any Ideas
Jam
Posted 2nd Sep 2010 at 01:56
simonjames
can you put it on axle stands and put it in gear and see if you can hear where it comes from?
tbh it could be from anywhere top suspension mount, wishbone bush, track rod end, ball joint etc etc
MY EBAY ITEMS
07943066306
Posted 2nd Sep 2010 at 02:26
jamanna85
Ball joints are new and measure up to the originals
wishbones are original but have new bushes,
Recon rack with new balljoints
new wheel bearings pressed to the shoulder.
havent tryed to spin the wheels in gear will try later.
but it dose sound like the universal joint clicking
Jam
Posted 2nd Sep 2010 at 14:23
ryangti6
If you dont have any joy with the driveshaft check the hole where the bottom ball joint goes into the hub, these can oval with age causing a bit of play but it does tend to make more of a knock than a click.
Ryan
Posted 2nd Sep 2010 at 23:15
SteviePut
Your wheels bolts are torqued up correctly aren't they?
Posted 3rd Sep 2010 at 01:55
jamanna85
Thanks for your ideas think i`v found it aparently a plate LSD makes horibal noises on the short side.
Jam
Posted 3rd Sep 2010 at 13:09
nadium
what plate ?
Posted 5th Sep 2010 at 15:40
