Author Subject: Suspension top mount issue
idnan
I was trying to find a source of yet another knocking noise and noticed that when I push the suspension down, the top hat part (circled red in the pic) moves up and down quite a bit.
The main bolt at the top of the strut is definitely tight and it looks like the rubber in the top mount is moving as I push down on the front end of the car.
Would this possibly cause a knocking noise when going over bumps and turning at slow speeds? The movement is only about 5mm when I try to push the front end down.
Posted 1st Sep 2010 at 03:02
knackered top mounts by the looks of it.
Posted 1st Sep 2010 at 03:18
mabgti
NV motors
Minimal movement is fine, thats what its designed in rubber forYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 1st Sep 2010 at 08:15
