Does anyone have a photo of them fitted to the car from this kind of angle?
Clicky
Bang'in 7 gram rocks!I have one gear, GO!
| Author | Subject: Xantia Disc Clearance |
berger
Seasoned Pro Location: Bathurst Registered: 26 Oct 2008 Posts: 1,068 Status: Offline |
How much clearance do the Xantia 288mm discs have on the lower balljoint?Does anyone have a photo of them fitted to the car from this kind of angle? Clicky ________________________________________ Bang'in 7 gram rocks!I have one gear, GO! |
more than that, but quite how much I can't remember!you can work out how much there would be by looking at the disc brake catalogues and comparing the offsets and widths. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
berger
welshpug! wrote: more than that, but quite how much I can't remember! you can work out how much there would be by looking at the disc brake catalogues and comparing the offsets and widths. Need to know the thickness of the material which mounts onto the hub though which they dont give you. You're only given the height and thickness of the disc, so you can have a couple of mm variance if the mounting face is thicker on one disc compared to another. ________________________________________ Bang'in 7 gram rocks!I have one gear, GO! |
good point ![]() some do specify that dimension iirc, but you do often get variations ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Rich E
berger wrote: welshpug! wrote: more than that, but quite how much I can't remember! you can work out how much there would be by looking at the disc brake catalogues and comparing the offsets and widths. Need to know the thickness of the material which mounts onto the hub though which they dont give you. You're only given the height and thickness of the disc, so you can have a couple of mm variance if the mounting face is thicker on one disc compared to another. The mounting material is 7mm on the 288x28mm Xantia discs. There is a 0.8mm ± 0.1 offset between the mounting face and the outboard disc face, and the total disc thickness is also subject to a ± 0.1 tolerance. So, if (and it's a big if!) I’m reading the drawing correctly the distance between the mounting face and the inboard disc face should be 27.2mm ± 0.2 ________________________________________ Rich |
