Author Subject: 205GTI hubs on 306?
snillet
Have i understood things right, that 205GTI hubs fitted to a 306, will give a bit more negative camber?
How much?
Are there any other "cons" with this?, positions of steering arm etc?, i donīt want to end up with a bad alignment issue....
Member of Peugeot Sport Club Sweden
http://www.peugeot-sport-club.com/
My son: http://www.youtube.com/watch?v=jzjSBKkMHDA
Posted 31st Aug 2010 at 19:22
smighall
Smeg-all
No more negative camber No
They are heavier than gti6 ones and only come with a 16mm balljoint socket. However it looks like you have a P1 6 so that probably has 16mm balljoints anyway.
The other thing to note is that not all of them come with ABS so don't have the sensor hole.
Meh
Posted 31st Aug 2010 at 19:39
snillet
Iīve noted the ABS / Balljoint thing, belive i have 16mm balljoint actually, since itīs a -94 S16....
Have seen comments here and there about the negative camber gain with 205 GTI (1.9 JA/JAZ) hubs and was seeking info with this questrion here.
You absolutely positive thereīs no gain in negative Camber?
Weight alone would keep me off it though Happy
Posted 31st Aug 2010 at 19:55
alastairh
I wouldn't be so sure.When you fit 306 hubs to a 205 you gain positive camber Wink
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 31st Aug 2010 at 22:42
snillet
Which,...... isnīt much of a "gain" really Happy for track use at least.
Posted 31st Aug 2010 at 22:57
they are no heavier, but the later hollow cast design used on the later 306's is meant to be stronger, though an S16 will have the same earlier type as the 205.
Posted 31st Aug 2010 at 23:54
