Author Subject: smoothing??
blaxx
what do i need to do or buy to do smoothing or debadging to my ph1?
Posted 31st Aug 2010 at 02:49
mr swampy s16
**BAD SELLER**
on my phs 1 i had
wing indicators welded and smoothed
front bumper recess filled and smoothed
door locks filled and smoothed
idealy all body shop work unless your good with welding, filling and sanding
Posted 31st Aug 2010 at 02:55
blaxx
is there a guide anywhere ? as i have no idea what to do ?
Posted 31st Aug 2010 at 03:02
blaxx
just need the bonnet doing with no badge i mean sorry
Posted 31st Aug 2010 at 03:03
mr swampy s16
**BAD SELLER**
to do properly you need to weld a plate in,
grind the welds back then apply a thin layer of filler beofre respraying
Posted 31st Aug 2010 at 03:11
:: blade ::
On a ph1 there is no need in welding, get some expanding foam in the recess, sand to the shape u want, whack a few layers of fiberglass on the fill with filler sand and spray Smile
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 31st Aug 2010 at 20:23
BrianM
If it was me, i'd be getting some welding done regardless. It reduces the chance of the panel flexing as much which may make it crack Smile
'13 208 Gti Bianca White, '99 Bianca 306 Rallye, '92 309 Goodwood GTi 5dr, '92 Miami Blue 309 GTi 3dr.
Posted 31st Aug 2010 at 05:59
mr swampy s16
**BAD SELLER**
Thinking about there isnt a badge on a phs1 bonnet its in the grill!
That can be done the way blade said.
Posted 31st Aug 2010 at 12:43
