ebay clicky
If someone could confirm one way or another would be most appreciated!
Cheers.
| Author | Subject: Coil suitable for Omex and bodies? |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
Just wanted to check if this coil is one that is suitable to run on an Omex ecu and throttle bodies?ebay clicky If someone could confirm one way or another would be most appreciated! Cheers. |
depends which Omex, some need a wasted spark coilpack, in which case anything like that off the 8 valve xu or earlier TU enignes will do, as would a ford or GM coilpack, leads commonly used are ones like GM C16/18XE ones.or you could trim a few lugs off the head and use the 16v xsi coilpack which doesnt need leads. other ecu's higher up in the range will work the standard gti6 coilpacks just fine. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
devere
This is for the omex 600. So wont work with the standard gti6 coilpacks. If this one i linked to was suitable il just get this i think.. As long as it will work with the 600! lol |
miles
Yes that will work, I'd just get a XSi pack thou and with some triming you have a neat solution instead of HT leads kicking around________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
