Author Subject: Car won't start..
fugs
I just fitted a roll cage and seats etc to my Gti-6. Its been sitting now for about 3 months without being started. Symptoms are strange and not what I'd usually associate as being normal problems. I think my welding may have damaged some electronics i.e the ecu. I had the battery dissconnected while welding to try stop any curents running about where they are not wanted.
Symptoms are...
Fuels pump runs as normal for 2 seconds when ignition is switched on.
No spark.
I don't think the injectors are opening.
The Dials on the dash are not going up and down when ignition is switched on like they were.
Engine is turning over.
Lights on dash all seem ok.
Fuel gauge not working with ignition only.
Engine warning light is staying on when turning over.
Imobiliser went through the usual routine after reconnecting battery.
I think I have an ignition problem and may have burned out my ECU.
Anyone got any ideas?
Posted 30th Aug 2010 at 01:54
possible crank sensor issue.
Posted 30th Aug 2010 at 02:04
fugs
How do I get to that sensor? Could that effect the Fuel gauge and dials not lifting?
Posted 30th Aug 2010 at 02:14
fugs
Electgrically I am a disaster but how would I test this sensor with a multimeter?
Posted 30th Aug 2010 at 03:12
fugs
I took out the crank sensor. Lookied very dirty so I cleaned it and piopped it back in. No joy. I'm collecting a new sonsor tomorrow. I also removed the double relay which I think feeds power to the ecu and am going to try get one in a scrap dealers. Any other Ideas what it might be?
Posted 30th Aug 2010 at 19:23
black 6
Is that the sensor on top of the gearbox? Mine would not start once, loads of power in the battery, it would just turn and turn but never fire. Swapped and started first attempt.
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 31st Aug 2010 at 01:36
jimbamboon
checked fuse number 6?
clicky code for my benefit
Posted 31st Aug 2010 at 02:24
gocart man
Well worth a check is below battery at the front you will find a couple of the harness connections that screw on like screw caps, one runs all the ignition side. Mine would not start after a period of off road time whilst sorting bent conrod, checked everything as normal then on the off chance thought I would disconnect to see if water had got inside and it turned out to be loose. Reconnected and all fine first turn..
Posted 31st Aug 2010 at 03:16
fugs
Tried all of the above but still no kick at all. New crank sensor and another relay tried. Fuse 6 is ok. What is the tiny button beside the key switch for?
Posted 31st Aug 2010 at 21:46
tried the relay on the back of the battery box?
Posted 1st Sep 2010 at 04:36
fugs
Yes but only tried a second hand one. I might see about testing it. Whats puzzeling me is the way the dials are not working. The fuel guage is not working at all.
Posted 1st Sep 2010 at 10:31
fugs
Is it possible to change the e3cu for a second hand one? Or is that a dealer only job?
Posted 1st Sep 2010 at 10:32
fugs
Vin - Vf37crfsw32310200
Build Code - 7745
Posted 1st Sep 2010 at 11:38
fugs
I'm looking for a coil connection 15 or + if anybody knows it?
Posted 3rd Sep 2010 at 00:54
black 6
Tiny button on the steering column disables the ultrasonics (hold it downn alarm light will come on solid) then you can alarm the car with the windows open so not your issue. Have you checked the fuel cut off switch to make sure that is not faulty. You are 100% you have fuel on the rail?
Posted 3rd Sep 2010 at 14:52
fugs
I have a haunted Battery. When you read across the terminals its 12v. When you crank the engine it drops to 7v and its finally packed in altogether. Hopefully a new battery will sort it.
Posted 4th Sep 2010 at 19:51
scoty18
From your battery test it defo sounds like you need a new battery.
  • TEAM DIABLO!!
  • Posted 7th Sep 2010 at 02:41
    fugs
    Right the car is still not started but after doing some tests on the ecu and with a good auto electrician it looks like either the ecu has a fault or the key fob coil reader is fupped. Think I'll get an unlocked ecu.
    Posted 8th Sep 2010 at 14:52
    james_gti6
    Was the battery disconnected when welding the cage in. as you may have spiked the ecu
    if i dont see you in the mattress il see you in the spring
    Posted 8th Sep 2010 at 15:44
    fugs
    Yes James it was.
    The immo is more than likely the problem as we have figured it can't read the key. ECU seems fine.
    So If I get an ECU with the immobiliser removed will it work?
    Posted 8th Sep 2010 at 17:28
    scoty18
    when you got the roll cage fitted did you have the dash out??
    Might of left something disconnected perhaps
  • TEAM DIABLO!!
  • Posted 8th Sep 2010 at 21:58
    fugs
    I broke the Key reader!
    I need to get an unlocked ecu.
    Posted 9th Sep 2010 at 17:44
