Author Subject: Difference engine XU10J4RS & XU10J4R
yoontje
I would like to know the differences between the XU10J4RS Gti-6 engine and the cabriolet XU10J4R engine.
and is it possible to fit the gti-6 gearbox onto my engine?
and what is the rev/speed ratio in 6th gear?
haven't been able to find it out.
If anybody could help, I would really apreciate it
Posted 25th Aug 2010 at 08:46
anth_gti6
There are a lot of subtle differences between them. The head for example is more flowed, I believe the oil spray bars are different as well for example. Obviously in cams, inlet and exhaust manifolds are completely different.
ex white Phase 1 Gti6, killed at cadwell park in November 07
Posted 25th Aug 2010 at 13:46
yoontje
tnx, so it should be possible to fit the gearbox. Smile
I would like to have better fuel economy on the highways
Posted 25th Aug 2010 at 18:53
fozzy_255
Gearbox will fit, but u will need to change the gear linkages and cable for reverse gear. You will also need to fit the gti6 steering ram as the the N/S wheel will rub on the gearbox on full lock
Posted 25th Aug 2010 at 19:05
I don't think you'll get better economy as 6th will probably be very similar to your 5th gear.
Posted 25th Aug 2010 at 19:17
anth_gti6
6th in a gti6/rallye is nearly the same as 5th in an xsi Yes the 6gears just gives you more options to keep the car in the higher power band for longer.
Posted 25th Aug 2010 at 20:15
yoontje
120kmph is about 3500rpm
on the gps im driving 111kmph at 3500rpm
Posted 25th Aug 2010 at 20:59
