Author Subject: Grease on headbolts
kriz5176
Looking at various threads and Pug manual it says to coat the threads and under the head of the bolts with Molykote g rapid grease. I presume this is to get a true reading of the torque value. as this is harder to get hold of than rocking horse crap, I was hoping someone could suggest an alternative.
chris
Posted 21st Aug 2010 at 23:36
indeed that is the reasoning, most sets come with a sachet of grease for this purpose, otherwise any moly grease will do.
Posted 22nd Aug 2010 at 00:48
kriz5176
Thank for that. That has saved a lot of internet searching
chris
Posted 22nd Aug 2010 at 01:59
used sparingly mind you, as the head bolt threads in the iron XU block are blind, i.e closed at the bottom.
excess grease can cause a seal and hydraulic pressure under the bolt, giving a false torque reading in worst case scenario.
I dont think it's likely to happen in an XU as theyre quite sturdy, but it has been known for hydraulic pressure under a headbolt to crack a cylinder block.
Posted 22nd Aug 2010 at 02:05
