displaying posts 201 to 225 of 227
Pages (10): first .. 8 [9] 10
Author Subject: High Boost Supercharged Rallye
Post #201
russbez wrote:
accidentally recorded me changing tyre while using my phone as a light.... i really need to cut down on my swearing Yes
LOL where is said video?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 2nd Sep 2013 at 22:40
russbez
Post #202
nae chance id never live that one down LOL
My Rallye project thread
Posted 3rd Sep 2013 at 07:20
russbez
Post #203
having gearbox/transmission issues after driving like a fanny
Posted 9th Sep 2013 at 12:11
russbez
Post #204
removed gearbox again, clutch must of been slipping due to oil leak from crank seal Sad
was not bone dry last time i took box off tried to give car benefit of the doubt... silly me
few weeks later oil leak got worse... then causing standard clutch to slip at high RPM
oil and heat spots on flywheel
bought new flywheel bolts from Peugeot
also sourced new clutch cover to flywheel bolts
doesnt look like much but was a fair bit of oil about engine bay
cleaned as much up as i could with dry rags
got an Engineering firm in Inverness to grind flywheel flat
replaced crank seal had a Pug mechanic doubt check my fitting skills of the seal Farmer
possibly controversial but refitted my "old" Helix paddle, wasnt much wear in it. Cleaned up Clutch cover plate with clutch cleaner.
car isnt used that much and they arent exactly cheap - could not really justify another £400/500 buying Paddle full kit
gearbox back in..... again
starting to get a bit cold for all this carry on, car back together done a few hundred miles in last two weeks cars back in storage for now! Car feels great in the dry not much fun in busy traffic!
Planning 2.5 inch bore exhaust instead of the wee restrictive 2" Scorpion... still to go see Longlife
half planning Magnex even if it is a temporary fix for now.
Posted 20th Nov 2013 at 15:34
russbez
Post #205
passed its Mot for the year, didnt have to do anything.... awesome feeling!
new 2.5" exhaust is getting fitted tomorrow, hopefully!
Posted 21st Mar 2014 at 10:02
Post #206
Nice one did it "pass" the emissions lol
Posted 21st Mar 2014 at 10:14
russbez
Post #207
It did Thumbs up
Posted 21st Mar 2014 at 10:37
dcc
Post #208
Just an observation:
The clutch isn't going to bite properly for the full life of the friction plate on that flywheel now.
You need to get the clutch pressure plate area ground the same distance as you've had the clutch surface ground, else you've effectively relieved the same clamping force on the clutch.
205 GTI
Xsara HDI
Posted 21st Mar 2014 at 13:13
Post #209
yeh, what he said.
Posted 21st Mar 2014 at 13:15
rallyestyle
Post #210
I have a 2.5 longlife on mine, does the job very nicely, rather lous though!!
Just Drive It
Posted 21st Mar 2014 at 13:29
russbez
Post #211
cheers dude, would never of thought about that - suppose the company that done it could of maybe mentioned this? Sad
doubt ill be taking gearbox off anytime soon
very harsh on normal driving but seems to be working great for now
rallyestyle wrote:
I have a 2.5 longlife on mine, does the job very nicely, rather loud though!!
dreading the how loud the 2.5" Magnex is going to be, getting it modified to remove a restricted point in the exhaust
hopefully Saturday so fingers crossed
should do for summer i guess while House gets started Ninja
Posted 21st Mar 2014 at 15:52
mcvite
Post #212
Stunning work project russ,well done!!!! Thumbs up
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 21st Mar 2014 at 16:39
rallyestyle
Post #213
How are you getting on with the gearbox's by the way? Have you blown may apart since going HB? Dunno Not sure how many HB's there are these days, normally LB or SB.
Just Drive It
Posted 21st Mar 2014 at 17:08
russbez
Post #214
well iv only done around 5/6k since highboost
havent blown any... yet Dunno
Posted 21st Mar 2014 at 19:06
chrisd306
Post #215
I've not posted on here for ages!! Got the Volvo fixed yet Russ?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 22nd Mar 2014 at 03:59
rallyestyle
Post #216
That's pretty good going from what i understand LOL Id be worried every time i used 3rd Doh
Just Drive It
Posted 23rd Mar 2014 at 10:12
russbez
Post #217
Nope, bought a Volvo C30 to replace the ole Estate... had it a week then Blower motor blew.
Volvo only repair requires some gay Volvo only tool to remove old unit Thumbs down
Arnold Clark Volvo have had it since end of February...
doubt ill be keeping it for very long... no other Volvo Dealers up here and there customer service stinks big time.
never phone me back, rude w**kers
Got the 2.5 bore exhaust fitted to Rallye last night Ninja
Posted 23rd Mar 2014 at 12:45
rallyestyle
Post #218
russbez wrote:
With a decat for 'private' road use i assume? Smoke
Just Drive It
Posted 23rd Mar 2014 at 18:55
russbez
Post #219
Magnex isnt much louder than my Scorpion
so far less poping and no flames
Posted 23rd Mar 2014 at 22:35
russbez
Post #220
spoke too soon
Third gear is making a lot of mechanical noises Angry
I can avoid using that gear for now, i have a spare gear box but will need to get LSD switched over too.
Too busy trying to sort house build and i certainly do'nt have the space for doing it at the moment
Posted 22nd Apr 2014 at 08:50
Post #221
Russ I'm currently fitting my massively massive high boost cooler and finding it a pain in the arse to fit it and the charger cooler as well as the oil cooler all behind the bumper.....
Any more pics of how your charger cooler is mounted vertically and clearance between the intercooler and the Rad?
Think we finally figured out where both can go this evening but would be good to see how yours is done.
Posted 9th Jun 2014 at 23:32
russbez
Post #222
sorry pal just seen this!! will pm you
theres a few pictures in my thread here, i trimmed some black plastic bits off of my radiator iirc
it is very very tight
Posted 9th Jul 2014 at 10:12
russbez
Post #223
start of this month i finally got time to sort gearbox
joys of nackered roads and going too fast....
it is safe honest LOL
switching LSD diff from box with damaged 3rd gear to spare box i had
Qualife-
Standard-
Posted 29th Aug 2014 at 14:56
russbez
Post #224
back on
Posted 29th Aug 2014 at 15:00
russbez
Post #225
back on the road for summer, had a boost leak over winter...
after spending a few hours messing about checking pipework and rubbers, i believe the welded joint had been cracked (again) by excessive engine movement
also made sure leak wasn’t along throttle assembly parts, used a small amount of gasket sealant for that
got pipe coming off Supercharger redone like other forum members had done :
first off got the old pipework off the charger
a 50mm to 63mm reducer, new 50mm pipework and old pipework to reuse get angles off of
bit of work
new pipe Smile
car now running good again, needs a windscreen and few minor bits for Mot
Posted 19th Mar 2015 at 16:09
