Author Subject: 307 Diesel, Bleeding clutch
spiky
anyone how the procedure?
sometimes the gear stick is stuck and wont go in any gears, then a few pumps of the pedal and it's fine,
so think there is air in the system,
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 17th Aug 2010 at 12:57
mechanical_repairs
We use a pressure bleeder that sits on the reservoir and then it's just a case of opening the bleed nipple.
I don't think you can do it manually you may be able to do it with a oil can filled with brake fluid doing it backwards, have done this before.
Carl
Posted 18th Aug 2010 at 02:12
spiky
the reservoir, this shared with the brakes?
where is the bleed nipple? on gearbox?
sorry i not even taken the car apart yet.
cheers for info, i got a ezebleed, that should do it shouldnt it?
MY YouTube Videos'
Posted 18th Aug 2010 at 02:22
streetbadger
bleed it the same as your brakes only you have to lift the clutch pedal up manually, bleed nipple is on the slave cylinder on the gearbox, probably find clutch master or slave cylinder need replacing due to not holding pressure, usually the master as its a bit of a pig to get to, would rec to change both the famous blanket repair!
Posted 18th Aug 2010 at 02:35
spiky
gearbox, dont need to come off though does it?
never done any work on a hydraulic clutch, i know how to brakes though
MY YouTube Videos'
Posted 18th Aug 2010 at 02:37
yeah they do share the brake reservoir, not worked on the clutch on one of these yet though.
if there is air in there its possible that a component needs replacing, I think leaking slave cylinders are not uncommon, not too bad at about £30 from a dealer though.
the slave cylinder is on the front of the gearbox on these, not an internal one like some fords.
Posted 18th Aug 2010 at 02:48
bobdylan_55
Just hope its not the new ones theyre selling with sealed hoses Wink if it is you need to buy the whole hydraulic system as the slave cylinder doesnt have a bleed nipple on it.
309 GTi6-T
Posted 18th Aug 2010 at 03:08
spiky
ok, will have a look tomorrow then, cheers guys,
it's a 2002 307 hdi, so fingers crossed it's the "old" version
MY YouTube Videos'
Posted 18th Aug 2010 at 03:28
1.4 1.6 or 2.0? 5 or 6 speed if its a 2.0?
I haven't seen any 307's with single piece hydraulic clutch units, earlier 406's had those.
Posted 18th Aug 2010 at 03:36
spiky
it's the 2.0 hdi fap 110bhp 5 speed
MY YouTube Videos'
Posted 18th Aug 2010 at 03:37
davedgti6
On my 505 it recommends reverse bleeding the clutch slave cylinder in the Haynes manual, never done it but apparently you have to attach a piece of tubing between the bleed nipple on the front caliper to the bleed nipple on the slave cylinder, loosen both nips then pump the brake pedal, sounds mad but suppose it would work,
Probably no use to you though LOL
Posted 22nd Aug 2010 at 02:17
