I was wondering if instead of fitting 406 brembos with 288mm xantia discs i can fit the 307 xsi 302mm discs. I have 16" wheels.
307 XSI specs
Xantia V6 specs
306 GTI6 specs
| Author | Subject: 406 Brembo with 307 XSI discs |
FatBastard
Regular Location: Amst Registered: 30 Oct 2005 Posts: 190 Status: Offline |
Hi all,I was wondering if instead of fitting 406 brembos with 288mm xantia discs i can fit the 307 xsi 302mm discs. I have 16" wheels. 307 XSI specs Xantia V6 specs 306 GTI6 specs Cheers |
bellcp306td
Regular Location: Bedlington Registered: 10 Aug 2009 Posts: 166 Status: Offline |
You might be able to but it will not be bolt and go you will have to make some adapter bracket for the Brembos. RS Brembos and a kit from Ash is way! better.________________________________________ Where did the road go!Chris |
FatBastard
But It seems that the 307 offsets are closer to the 306 offsets than the xantia ones.getting calipers in my country is almost impossible and i do have the 406 brembos, so i cant afford Ash's kit, even though i would like that. |
But the xantia offset disc works with the 306 hub and the offset on the 406 calipers. If you change the disc offset it may not work.________________________________________ Nothing to see here |
Rich E
If those drawings are correct then they should fit.You will need to check the obvious things like space inside the caliper and also bear in mind that the outer pad will need to be 2mm further in than before so check the pistons can still fully extend the pad. ________________________________________ Rich |
FatBastard
Ok thanks.I will update if/when i know those discs fit the Brembos. |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
any joy? |
theyre too big, the radius of the 306+307 mounting lugs is smaller than the 406, so you have to run a smaller disc.the xantia/C5 discs are perfect, if a tad squealy.... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
