Author Subject: Urgent: Clutch cable
russian
I know this is probably the 189495th post about this but still.
After this pig of a job, one would think everything would work as it should, but no.
Have problems selecting gears, especially reverse, biting point is right near the floor.
Have tried pulling the pedal, stamping on it hard a few times, driven 150 miles from Wales and it's still shit! Angry
Any suggestions?
Posted 16th Aug 2010 at 17:13
pete26
Mines exactly the same as you discribed also selecting reverse is a mother f*cker. Brought a valeo clutch and pug clutch cable also. Although the clutch isn't slipping. I still reckon its both in my case . But defo give the cable a shot.
Ph2 Black GTI6
Ph3 China GTI6
206 xsi manstone daily runner (GAY)
Ph1 Cherry Red GTI6
307 HDi 110
Posted 16th Aug 2010 at 23:51
russian
Should mention, i just changed the cable because of some major judder, but obviously now things are even worse.
Posted 17th Aug 2010 at 00:05
will130787
Does your cable need adjusting on top of the gearbox housing??
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 17th Aug 2010 at 13:59
russian
How do i go about checking / adjusting it?
Posted 17th Aug 2010 at 16:07
will130787
The cable goes into an adjuster (what looks like an adjuster) on top of the box.....
Just underneath the battery tray:
Posted 17th Aug 2010 at 17:50
russian
Can't adjust anything with that plastic thingy.
Also noticed that can easily select gears in the morning, inc the reverse. However after driving for 15 mins it becomes worse.
Posted 18th Aug 2010 at 22:01
will130787
Have you changed your gb oil recently? Also it could be re clutch fork bearing iirc when I took my box apart there were two plastic washers that the clutch fork sits in, they could be 'greaseless' and when they get hot create friction making it harder.....
Have you got Pauls number? (from reading) if you have give him a shout, if not I have.
Posted 19th Aug 2010 at 00:53
russian
Oil was changed 3 months ago. Everything is pointing where the box would need to come off, hopefully can arrange this with Paul as you say.
Either way, thanks for your input.
Posted 19th Aug 2010 at 03:03
Denis
You can try pulling on the cable at the gearbox end – this will cause auto adjuster to re-adjust and might change the biting point on the clutch.
With clutch judder – when changing the clutch it would be good to skim the flywheel.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 19th Aug 2010 at 04:43
