Author Subject: Advice required
mcfc1987
Had an MOT and the only advisory was passenger ball joint, I have got a slight knocking so will be replacing these on both sides, while I am down there I thought I may as well replace some other bits so I was just wondering what else I should be replacing to sharpen everything up again
Ball Joints
Track rod ends?
Drop links?
I have already got some Rich_W's roller bearing wishbone bushes on there from the previous owner so they have been re-greased.
*edit; springs and shocks have already been upgraded, koni adjustable shocks and eibach 30mm springs so these are fine
Posted 16th Aug 2010 at 16:15
mark-house
Change anything thats not been changed lol
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 16th Aug 2010 at 23:19
anth
Thats a major black hole mate.
Shocks, top mounts, balljoints, drop links... Then you have to consider the rear too.
Posted 17th Aug 2010 at 01:05
mcfc1987
Right, getting a list together of parts i require.
For the front;
Top mount rubbers and bearings
Track Rod Ends
Ball Joints
Drop Links
For the rear;
??? what should I be looking at here
Posted 19th Aug 2010 at 12:55
braymond
Good call on replacing the droplinks. i replaced mine the other day, and whilst they looked alright, with not much wear, replacing them did get rid of my knocking noise.
Rallye-R
Nurburgring article
Posted 19th Aug 2010 at 14:55
lotek
have your hub looked at to make sure theres no ovalisation aswell. its getting common now Yes
Posted 19th Aug 2010 at 15:12
anth
For the front;
Track Rod Ends
Ball Joints
Drop Links
For the rear;
Rear Beam mounts really. Also the shocks if needed.
Posted 19th Aug 2010 at 15:23
manthos
i've just solved the same problem, when on the MOT they advised ball joint it was actually the hub ovaling, worth changing ball joint too tho as there cheap. i also changed my arb drop links as thats where the knocking was comeing from.
Team SUPERCHARGED
Old Project thread
Posted 19th Aug 2010 at 15:32
mcfc1987
How much would i be looking at for a new wishbone from pug? Also do they come with all the bushes required?
Posted 24th Aug 2010 at 14:34
jon boy
Had a quote from peugeot for wishbones a couple of weeks ago.
IIRC they were around £111 +VAT each for the wishbone including bushes but the ball joints came seperately at about £35 +VAT each.
Posted 24th Aug 2010 at 18:19
anth
Just change the bushes, get them from citreon as peugeot do not sell them seperately
Posted 24th Aug 2010 at 20:01
