Author Subject: mot failed
spaniel
i just had an mot done and it has failed on the brake load sensing valve and hand brake efficiency. i know how to free up the sensing valve but was wondering if this is causing the handbrake problem.
the bloke at the garage said to take the drums apart and clean out the brake dust but when i got outside i realised they are discs on the back.
the hand brake cable shouldn't need adjustment it doesn't come up to high.
Posted 14th Aug 2010 at 19:41
allesclar
if the mechanic said you need to clean out the drums and you have discs, i would really consider taking your car else where Laugh my ass off
Team allesclar ®
Posted 14th Aug 2010 at 19:59
kit
Laugh my ass off name and shame the garage who told you that. I beg of you!
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 14th Aug 2010 at 20:09
spaniel
yeah i know but not alot of help really, guess i'm gonna have to get the load sensor sorted and try a few hand brake turns
Posted 14th Aug 2010 at 21:55
sixysix
Spray lots of WD40 on the spring valve and wiggle it about until it moves freely.
Make sure disks and pads are all ok.
Right before you take the car in for retest, drive round the block with the handbrake lightly applied (a couple of clicks should be alright).
Now watch it sail through the efficiency test Wink
If all the above fails, check that your drums have not fallen off the car Whistle LOL
Take a look
Posted 15th Aug 2010 at 02:12
smegal
You can tighten the handbrake cables up by a couple of turns too.
Ex SC-6
Now in a Megane R26
Posted 15th Aug 2010 at 17:27
I wouldn't touch the handbrake travel till you sort the load sensing valve, its likely that the discs are just all rusty and it may not need adjusting at all.
Posted 15th Aug 2010 at 17:39
spaniel
i have been under there today and it was moving freely, i have sprayed some wd40 on anyway but it seems ok.
i had a thought now i am home and could it be that the part that pushs the lever out is not working properly? (sorry but don't know alot about the brake set up but am trying to learn)
Posted 15th Aug 2010 at 21:22
it might be that the bit attached at the lower damper bolt isn't located properly, have seen many garages get this wrong.
Posted 15th Aug 2010 at 22:12
spaniel
not too sure what your talking about but will get onder it tomorrow and have another look
Posted 15th Aug 2010 at 22:47
spaniel
i have had a look today and got someone to press the brake for me but the load sensor arm isn't moving, as it is not seized then it must be the piston that pushes it that has gone. i have nver had to change one of these before so any advise or guides would be good
Posted 16th Aug 2010 at 23:48
