Author Subject: hevy clutch
levon1987
hi i have 2.0 HDi year 1999 my clutch is rock hard. changed cable made it very light but after a week rock hard again im desperate to make the clutch lighter i gues this is still the original clutch its not slipin feels ok but i heard it takes ages to slip...will a new chlutch make it lighter i hate to drive this car now becouse of the clutch ...any advice?
levon1987 has attached the following image:
Posted 11th Aug 2010 at 11:47
levon1987
ok i talked to a mechanic he sayed i need a new clutch or pressure plate basicly a new clutch kit...i hope this will solve problem i did 117k miles
Posted 11th Aug 2010 at 20:22
snoopy_410
It is most likely to be the pressure plate if you have already try'ed the cable, and if your having that done then you may as well have the clutch plate done too
R.I.P pete Sad
Team: Diablo 6
Team: YZF R1
Posted 11th Aug 2010 at 20:31
miles
Doubtfull, The main reason for a heavy clutch is the cross shaft (Clutch arm) and bearings as they tend to rust in the bottom bearing making the clutch stiff, the amount of so called mechanic's that say change the clutch is quite funny as the shaft and bearings are only a shade over £50.00
www.pugracing.com
Posted 12th Aug 2010 at 03:29
levon1987
hm its saves a lot of money. yso sayin 50pounds with vat??? so no new clutch but clutch arm...i mus say there is a aqueaky noise near the clutch arm when engine is cold ...
Posted 12th Aug 2010 at 12:35
levon1987
the clutch arm bearings can you decribe me how its done? do they have to remove the gearbox??? how long it takes?
Posted 12th Aug 2010 at 12:48
miles
Yes it's remove the box as the arms run's thru the box and you'll see the top and bottom bearings are white plastic/Nylon
As said a huge mistake of not replacing these when the clutch is being done, I've done a few and it really does make the clucth feel light (Well not Ford light) but not heavy like most 306's are.
www.pugracing.com
Posted 13th Aug 2010 at 03:33
its less than £2 for the pair of bushes if the cross shaft is still in fair condition.
Posted 13th Aug 2010 at 03:46
ablister
£2 may seem cheap but gearbox needs to come out to replace them!
306 rallye, Richard Longman engine
rc10gt
Posted 13th Aug 2010 at 23:08
beez_neez_gt
Its not hard to take the gearbox off its just takes time and can be awkward to put it back on.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 13th Aug 2010 at 23:13
monty-69
Don't just change the bushes without the clutch, im sure the pressure plate springs go stiffer over time combined with the bushes wearing oval/seizing. Think the new bushes come with a small hole in lower one to help lubricate in future.
Posted 14th Aug 2010 at 01:23
tvrfan007
Handy information.
I just got used to living with my heavy clutch - it's the original and it's done....214K rofl.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Aug 2010 at 16:16
