Author Subject: up and down idleing when dipping the clutch.
turna123
Hi, have been looking at various threads on here recently. Im experiencing problems where i come to a junction or whatever, and i dip the clutch and the revs go up to around 2k, cum down and up once more to 1.5k, then settle. I have read it may be the ICV, but can't find the threads now. What do people think?
Posted 10th Aug 2010 at 19:50
honestly3k
Does the car cut out atall (stall?) when dipping the clutch and general other rev anomalies?
If so, its probably the ICV yes. Disconnect the battery, take the ICV off, clean it with carb cleaner, reattach, then put the battery back on and it should sort things out. If not you should look elsewhere for the answer... Smile
Posted 10th Aug 2010 at 22:00
turna123
hi, ye the car has stalled before, not so much recently, but it has done. The car does sometimes, when dipping the clutch, the revs die quite quickly and go below the usual 900/1000rpm. But then it does just about keep itself going. To be honest, the main problem i'm having is the coming to a junction first thing in the morning, and the revs being all over the place before it settles. It is aswel quite hesitant when driving at times, which i have read can be the ICV...? What does every1 else think? thanks
Posted 11th Aug 2010 at 15:55
ballardpaul
Sounds like it mate. Give it a clean, will only take 20mins.
Nissan 350Z (300 BHP)
Posted 11th Aug 2010 at 16:10
turna123
where is it and how do you take it off? Thanks Smile
Posted 11th Aug 2010 at 21:53
honestly3k
Do you have a 6?
It should be right of the inlet manifold....under some sensors...pretty easy to remove thought cant tell you precisely as have not looked much at the 6 engine bay with only just getting mine and it being in the garage already! LOL
Posted 11th Aug 2010 at 23:01
turna123
lol oh ok mate Smile wel thanks, cant realy see it tho :S does anyone else have any ideas where it is? thanks
Posted 11th Aug 2010 at 23:11
ballardpaul
Have a search. I would take a pict but mines in a dif place now.
Posted 11th Aug 2010 at 23:13
turna123
ye but my problem is i don't even know what it looks like lol Sad if someone could take a picture and help it would be incredible Big grin .. Smile thanks
Posted 11th Aug 2010 at 23:16
honestly3k
Gimme a sec, il try upload a pic....Razz
Posted 11th Aug 2010 at 23:18
turna123
thanks alot pal Big grin !
honestly3k
Ok im 99% sure the ICV is located UNDER where i have circled red. Its a small black cylinder bolted into the manifold. Should just be a case of unscrewing it and pulling it off. Good luck my young padawan.
Posted 11th Aug 2010 at 23:21
honestly3k
Dont forget to disconnect the battery for atleast 15mins as this acts as an ecu reset, and will force the car to relearn the ICV and it will think a new one has been put on. You will need your radio code to reactivate ur stereo (if its standard) Smile
Posted 11th Aug 2010 at 23:26
ballardpaul
Yeah it is there. See the small pipe coming from the air intake just before the throttle body that attaches to the icv.
Posted 11th Aug 2010 at 23:28
ballardpaul
Or just unplug the ecu and plug it back in.
Posted 11th Aug 2010 at 23:29
turna123
the plug? thought that was the map sensor :S
Posted 11th Aug 2010 at 23:32
ballardpaul
What plug?
Posted 11th Aug 2010 at 23:34
honestly3k
Its underneath that sensor boy! Pay attention!
You cant see it in the photo as its covered by that sensor and the metal bracket thing....its underneath...you really cant miss it :[
Posted 11th Aug 2010 at 23:35
turna123
iv found it mate, thanks....also found on there a whole on the end with suction of air....? it has no end on it..is there supposed to b a breather or something? :s
Posted 11th Aug 2010 at 23:39
honestly3k
Not sure what you mean. But on my 1.8 it was an enclosed cylinder and when you unscrew it, it reveals a pronged bit extending from it, a valve bit that was covered in oil and muck....
Posted 11th Aug 2010 at 23:47
turna123
ye it is all covered in oil n muck haha....wot im sayin is, where the air is brought in to the valve, does it have something on the end of it? its bare on mine and is like a vacuum with nothing on the end of it
Posted 11th Aug 2010 at 23:50
ballardpaul
Im sure the small pipe that comes off the air intake should go into it.
Posted 12th Aug 2010 at 00:08
turna123
ye but i've got an induction kit, no standard to the car :S so....wot shud i do? buy a breather, or wot? will it make the car drive wrongly if it isn't attatched to the airbox etc?
Posted 12th Aug 2010 at 00:09
ballardpaul
mine just has a breather filter on it so i doubt that will make any difference to the idle.
Posted 12th Aug 2010 at 00:13
turna123
ah i see....thats all cool then Smile
Posted 12th Aug 2010 at 00:14
