click me for the vid
hope you can shed some light,
cheers
Iain
Black Ph1 XSi-6161.8BHP (Getting Better!!!!)
| Author | Subject: engin idling high |
:: blade ::
Senior User Location: Altrincham Registered: 21 Aug 2007 Posts: 697 Status: Offline |
hi all, just wondering why my car has decieded to idle funny, its revs on its own for abit, and doesnt go below 10k revs, i have changed the throttle body for one i ported and polished, but a have checked and there is no airleaks, what else could it be?![]() click me for the vid hope you can shed some light, cheers Iain ________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
stick the old throttle body back on see what happens.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
lwgti-6
Senior User Location: Nottinghamshire Registered: 27 Oct 2008 Posts: 906 Status: Offline |
Have you adjusted the accelerator cable adjuster on the throttle body at all?________________________________________ EX Bianca 6 owner,Now drives: Octavia vRS |
:: blade ::
nope its how it was before i changed the throttle body,________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
simonjames
Seasoned Pro Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
Adjust so cable is longer and all should be fine ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
:: blade ::
i can take the throttle cable out and it will be the same tho________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
simonjames
Has the little grub screw been adjusted to push the linkage open?________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
:: blade ::
which grub screw be this? the one on the butterfly in the throttle body?________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
simonjames
1 by the linkage that the cable attaches too if you disconnect the cable from linkage is it the same? can linkage be moved closed I.E sticking open but can be manually closed ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
:: blade ::
nope if i take the cable out it will idle the same, and the linkage moves freely, doesnt stick anywhere________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
simonjames
ICV sticking?seems strange tbh ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
dubious porting work probably...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
bristolxsi
Newbie Location: Bristol Registered: 23 Jun 2010 Posts: 15 Status: Offline |
mind does this as well and been trying to find the problem for ages i had a new ICV straight from pug and didnt cure the issue. |
smegal
Make sure the throttle body springs fully closed.________________________________________ Ex SC-6Now in a Megane R26 |
:: blade ::
I seem to have fixed it. Car seems to rev a little faster with this throttle body, all i have done is unplug the map sensor and plug it back in, going to take the ICV out and clean that next week and see if that sorts anything will keep u posted.________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
bristolxsi
Where is the MAP Sensor to on the engine? |
