Author Subject: ABS light on
binkagti
Hi my abs light has just come on and now the brakes are well dangerous lol.
Just wondering firstly how do i know which one has broken, what an abs sensor looks like lol, and best place to buy one from?
Many thanks
Oh how do you fit it aswell, not asking to much
TEAM Supercharged Rallye
Posted 9th Aug 2010 at 23:17
mechanical_repairs
Not much to them to be honest about £35 from places like gsf etc, most of them now need to be drilled out as they seize in. will need to go on a computer to see which one has failed or you could measure resistance with a multi metre.
Carl
Posted 10th Aug 2010 at 01:09
what Carl said, it doesn't affect the brakes one bit BTW, only the anti lock function, unless its a PH3 where it does the EBD.
Posted 10th Aug 2010 at 01:12
binkagti
When i braked in the wet the back end tried to over take the front? does that mean i have ebd
Posted 12th Aug 2010 at 02:30
binkagti
Just a quick bump to the above question really, my car is v reg
Posted 21st Oct 2010 at 03:02
oldbrownshoe
It could be clogged with just too much dirt on it's teethes,
as it did with my car, it went back to function normal after i cleaned thoroughly all 4 sensors .
French military victories?
Did you mean French military defeats?
Posted 21st Oct 2010 at 05:35
anderoo
You can test the sensors by checking resistance. The values are in autodata IIRC. I can post them up tonight if you want them?
You can check if you have ebd by looking at the rear beam, cars with it won't have the load sensing valve on it.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 21st Oct 2010 at 12:59
mabgti
NV motors
i can stick it on diagnostics for you binka on saturday as i'm essex on a job.. EBfD is only on later phase 3 cars without rear brake bias valves..
yours still on the original ecu??
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Oct 2010 at 01:35
binkagti
No mate running efi, any good??
Posted 23rd Oct 2010 at 05:53
miles
Could be a broken ring, Common on 06's
this causes the brakes to think they are locking up when they are far from it and making the ABS work far too early
www.pugracing.com
Posted 24th Oct 2010 at 00:17
craigy_87
think this might be whats wrong with mine, how would i go about checking/fixing it?
Posted 24th Oct 2010 at 01:52
miles
New shaft or wheel bearing on the rear, I know my my 306's ABS light came on it broke a 2 week old brand new sensor because of the ring snapping the end off,
www.pugracing.com
Posted 24th Oct 2010 at 03:21
craigy_87
with mine the abs light will come on an the car will jerk with the electrics dimming
i'll need to check the ring
Posted 24th Oct 2010 at 03:26
Rich E Forum Admin
The ABS is a self contained system and won't affect anything else when it fails so if you have electrics dimming when the ABS light is on then that points to an earthing issue.
Posted 24th Oct 2010 at 14:13
craigy_87
did think that, not sure where to look though
Posted 24th Oct 2010 at 17:31
