Author Subject: Gearbox issues at Anglesey
shakey
Went to Anglesey today looking forward to great day with lots of cool cars and top weather. However on the sighting laps the car jumped out of 3rd twice, both times when under full throttle.
After 8 or 10 "proper" laps we got black flagged due to a loud transmission noise which can only be described as like some dragging their finger nails down a blackboard.
This noise only happens when your off the clutch in 1st, 2nd, 4th, 5th and 6th - not in 3rd ?
Its goes into all gears fine no clunks or crunching.
Anyone got any ideas what this might be, the car recently had a new engine fitted and has a short shifter.
thanks
Posted 9th Aug 2010 at 00:45
jonnie205
sounds like a bearing and or 3rd gear syncro teeth on gear have stripped, does it drive in 3rd?
Posted 9th Aug 2010 at 00:56
shakey
Yep it drives in all gears
Posted 9th Aug 2010 at 01:22
rallyeash
sounds like the clutch release bearing but it should really do that in all gears.
309 3dr K20 Type R
Posted 9th Aug 2010 at 17:57
shakey
Is that a fairly easy fix or major surgery, i.e. box rebuild ?
Posted 10th Aug 2010 at 04:03
rcarney1989
its outside the box mate box needs taking out tho
Team:Kuwait Working :<
6 is in the uk in my garage :<
but shes going high boost when i return to the uk Big grin
Posted 10th Aug 2010 at 04:15
shakey
Nice one cheers fella
Posted 10th Aug 2010 at 04:17
For the hassle i'd get another box and chuck it on whilst you are doing the clutch. The bearing can't be done without the clutch plate.
You've covered all bases then Smile
Posted 10th Aug 2010 at 14:57
shakey
If I was to get another box would anyone have any advice on weather to replace it with a standard 6 box or perhaps go with something else such as a VTS or a 205 bearing in mind it's a track car and acceleration in 2nd, 3rd and 4th is more important that outright top end - I don't recall ever using 6th
Posted 10th Aug 2010 at 16:08
