Author Subject: thermostat housing
spaniel
basicaly the short hose that comes out of the bottom of the thermostat housing split last night, i have fitted it before but it is a nightmare as it is so short and the bolts that come out of the head to hold the housing are really long.
i was wondering that if the bolts that come out of the head can be removed so that i can connect the hose and then fit the bolts with the housing in place (probly won't make sense unless you taken it off before) anyone changed one before and got some tips?
Posted 8th Aug 2010 at 00:22
birk
Undo the 13m nuts on the back of the block that hold the metal pipe on, then you can slip the new pipe on and then the metal pipe again.
You can get away with just the one 13mm bolt i bet though.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 8th Aug 2010 at 00:30
spaniel
nice one will give it a go
Posted 8th Aug 2010 at 13:02
